after building my own SLA Printer, everything works fine except the tilt function.
The z-axis works fine, and the x-axis, which is used for the tilt doesn't. You can here some noise from the stepper but nothing moves.
I tested my Ramps and the stepperdriver with RepetierHost and everything worked. So the Ramps and the stepperdrivers are working and i didn't changed the voltage of the stepperdriver after i had set them up.
I think it must be a problem in the firmware but i don't know where. I've controlled the axis steps per unit and the direction and so.
Who can help me???
