5000 hours its for standart white led 4w?
Our printer installed 20w uv led.
But better result for 50w uv led.
- 3dprinter.org.ua
Deaner3D
- Joined: Sat Feb 11, 2017 6:18 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Been following this thread for quite a while now...
Any indications this is the same exact printer Wanhao is releasing, the Duplicator 7? Several people are saying their price will be $399 + ~$125 shipping. Their layer time is a claimed 5 seconds, and one of the few reviewers said he required a 6A power supply. 50W UV system would add up...
LacoDeLoco
The main parts are the same.
It looks, somebody manufacturing the LCD, electronics, and selling it to resellers, to assemblers.
5s curing time is for clear Fun To Do resin. (not all resins required the same curing time).
malamen
- Joined: Sun Feb 12, 2017 10:21 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi everybody! I want to get this printer.I need it for dental use.Thus,i need accuracity in all dimentions,i mean not only the size of pixel,but the whole object should be pricise.I made some thinhs with formlabs2.Can this printer do the same quality prints ? thanks!
LacoDeLoco
To: malamen
Define "the same quality".
Define it in numbers.
Then you can compare.
malamen
same quality as formlabs 2
csader
- Joined: Fri Dec 30, 2016 12:25 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
After lots of deliberation, I finally placed an order for this printer last night.
Recommendations for getting started? Tweaks to make right away? Things to check before printing? Longer-term mods worth doing?
Also ordered some Makerjuice SF Red and (another, I have many) Raspberry Pi 3.
Excited to get started.
Mechatroiker
- Joined: Wed Feb 01, 2017 5:52 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
LacoDeLoco
Its not easy printer.
But if you know, what are you doing, then ...for the money, they deliver excellent result.
But remember, nobody will teach you, how to use it,
Nobody will supply SW, and upgrades.
You have to figure out everything alone.
You need to learn, read similar topics, learn and read similar printers (Formlabs has excellent forum)
No automatisation, no "clever " software.
You will definitely spend some time with it, and around it
If you are happy with this, then the printer is near to perfect.
I will buy it again.
The printer allows me to learn a lot (pish me to learn a lot). With concrete questions you can ask, people will answer you.
Its much easier to buy a ready made printer and eventually modify it, then build a new one (I built a DLP printer and bought this PRONIKS)
