https://drive.google.com/file/d/0B4QD7f ... sp=sharing
Hello everyone,
I'm new to the club,
I noticed that the slide z sways sideways (warping), have you also experienced a similar defect, and how you solved,
thanks in advance
svs
Dear forum users ;
For this LCD printer , we formulated more reactive resin .....for decrease layer cure times..
when you order resin ;please infrom us about your printer brand for this new formulation
regards
savas from senertek
regards
savas from senertek
hi svs,
can you tell us about the cure time per layer on the more reactive resin?
looking forward hearing from you
goldi80
..0.03mm layers, first 4 layer 120sec, then 10sec using senertek cast red resin. user
dd
is making for me new resin maybe it will be better
svs
hope ..can be decrease to 1s per layer ( for 0.050mm layer height ) ....
users will test and report ...
goldi80
I try 3sek resin i have it prints black area it go through very sensitive resin is no good for LCD if 8sek for 0.035 I think it will be best for printing.
Try 30wat bulb is no good
Like to try matrix led it will be best for expand light and then 5sek per 35u
goldi80
russiangems
Odd
- Joined: Sun Dec 04, 2016 5:48 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hey russiangems
I used the settings in the first post here:
https://www.nanodlp.com/forum/viewtopic.php?id=305
...and the latest ( non-beta ) version of nanodlp.
Good luck
//O.
Good luck
//O.
