https://ru.aliexpress.com/item/11-11-Pr ... 57818.html
oh
this LCD is really cheap
I think the cost of the printer 250USD
- 3dprinter.org.ua
goldi80
Do you know resolution native and size?
- 3dprinter.org.ua
goldi80
this good to know if i brake my i will replace whit this on.NO hdmi ?
Do you know where can i buy the led i want to put 4x double or 2x on my lcd printer
Regards
Regards
- 3dprinter.org.ua
Axel
- Joined: Wed Dec 21, 2016 9:37 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thank you for opening up a forum about the Proniks UV/LED printer. Now, I'm really very interested to get one.
I saw the product in Aliexpress but im a bit hesitant because i havent seen any good reviews about It yet. Good thing I saw your forum and started following it. Im new to this hobby, and id like to get myself an sla printer. Im looking into getting the formlabs form 2, but im still saving up for it. It's really sky-high expensive. Im curious how this cheap printer would compare to the form 2 in terms of print quality and speed.
I'd like to know a couple of things before pulling the trigger, i hope you guys can help me.
I'd like to know about its print speed on 0.25mm and .5mm/layer resolution. Say I have to print 1000-1200 layers to the highest resolution 0.25mm per layer, how long will it print using a regular UV resin?
Also how's the surface of the prints, are they very smooth?
Im using a clear resin that is biocompatible, it is used in dental field. It is a bit viscous. Will this 3d printer printer turn the clear resin into a bit yellowish color?
I'm really Very excited to get my very first 3d UV/LED printer.
Thank you very much!
-AXEL
-AXEL
goldi80
Form 2 don't have f theta lens cheers!
idifix
- Joined: Sun Dec 04, 2016 12:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi Axel,
I don't have this printer, but Proniks should be better in term of resolution than Formlabs.
What is your biocompatible dental material, I'm working in the field
