I am looking for a good supplier of First/Front Surface Mirrors,. I am based in the UK but I have family that Work in the USA so a supplier there wouldn't be an issue.
I am looking for mirrors around about 100mm x 120mm, however they can be a bit bigger or smaller than this, I will adjust my projector distance to suit.
First/Front Surface Mirrors - Best Suppliers?
DepthDesign3D
- Joined: Thu Mar 12, 2015 10:45 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
4-6λ First Surface Mirrors | Edmund Optics
http://www.edmundoptics.com/optics/opti ... rrors/2077
Greetings DepthDesign 3D;
Please find attached, link to Edmund Optics;
Regards
Saeed
Regards
Saeed
Cation
Re: First/Front Surface Mirrors - Best Suppliers?
http://www.sciplus.com/p/MIRROR-FIRST-S ... -SMALL_248
All under $5ea but not always 100% perfect
Up to /63MM X 231MM X 9.5MM THK
badgerman
- Joined: Mon Apr 13, 2015 12:01 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I know this thread went quiet after April, but for the UK contingent you can get mirrors cut to your requirement from . I emailed them and a guy called Terry was extremely accommodating. I got a 130mm x 130mm mirror from them for £20 posted.
Chris
Chris
