this is good !!!!!!!!!!!!
Have galvo but i don't want to use without f theta lens.
Only on the middle you can print and slic3r don't have spot compensation.
Do anyone knows good f theta lesn for sale cheap and do the job.
see photo
Printy! A DIY Open Source 3D Printer!
goldi80
Re: Printy! A DIY Open Source 3D Printer!
- Attachments
- 1402LFW_51.jpg (10.71 KiB) Viewed 57225 times
maxjewels
- Joined: Mon Nov 28, 2016 1:22 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Printy! TE Open Source da di fai 3D della stampante di una!
In a printer of this kind would serve a LAN connection, a slot for SD cards and a beautiful display.
For the rest is fantastic, I'd like to see in detail the board between the galvo and Arduino
goldi80
Repetier have lan connection and web Software it works put gcode on it and push start i try it works .
boelle
- Joined: Tue Dec 27, 2016 11:14 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
@Gr3ymatter
Any updates?
Any updates?
educa
- Joined: Tue Jun 09, 2015 6:39 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Goldi, if you do the math, then if you throw your laser over a distance of around 250mm, then you can get a 60-80mm square build area with little or no deviation. After that if goes bad quickly but 60x60mm is for example not a bad part to work with
goldi80
I calculate the form laser beam is 0.145 dot, wen is on 145mm or from middle 72mm the beam is like egg 0.185 dot.
Regards
Regards
educa
145mm is also 2.5 times 60mm
cozmicray
- Joined: Mon Aug 10, 2015 1:01 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
What happened to printy?
any updates?
any updates?
