Hi everybody,
I've been a silent member of this forum for a couple of weeks now. This is my first post, so first of all I'd like to say hi and thanks to everybody who contributes to this forum. And of course a special thanks to Steve for creating this awesome software! I just finished the first version of my DLP printer. It took about two weeks to plan and one week to assembly and has the following features/ specs:
Projector:
BenQ TH681 Full HD, 3000 ANSI Lumen
Buildsize:
20x12x35cm
Mechanics:
2x Axis 16x4x40mm
2x NEMA 17
RAMPS 1.4 + Motordriver
1x Servo SG90 for the projector shutter
VAT:
Flexvat made of aluminium, acrylic glass and PTFE film 0.1mm
Any comments, suggestions and critiques are very welcome:
Printer:
VAT:
Projector Shutter
Thanks and best regards,
Matze
DLP Printer, FlexVat, Germany
sodium
Re: DLP Printer, FlexVat, Germany
nice job. and most important, seems no problems at all in your first print. time to tune settings.
what resin are you curing?
Matze
Thanks, I'm using Fun to do at the moment. But I received some Makerjuice today and I will that tomorrow...
Wonderful prints, excellent looking machine! I'm glad it's all working well for you.
how_eee
Why do you use acrylic instead of glass under ptfe?
Matze
@Steve: thanks
@how_eee: I use acrylic because i had to drill holes into it, to tension the ptfe film. Also small holes to remove the vacuum between the ptfe and the acrylic bottom...
FPanda
- Joined: Thu Dec 18, 2014 8:50 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hallo Matze,
I am from Germany, too.
Nice setup and good looking first prints!
Do you use for peeling an asymetric lift of the build platform like mUVe 1?
After a unsuccessful bargain of a Form1 clone on ebay I decided to diy a dlp printer.
regards
Alex
regards
Alex
Matze
Hallo Alex
Thanks a lot. It took a few days of calibration and trying out different build platforms/vats, but I'm finally finished with the hardware part. I'm using a FlexVat similar to this (http://projectsinterestsandetcetera.com ... m-flexvat/).
I think it's the best way to design a vat. It's really fast and it takes about 10 minutes to exchange the PTFE film once it's worn out or damaged. Good luck and PM me if you have any questions.
regards,
Matthias
regards,
Matthias
