Hi guys, I'm not sure what I did wrong here but my slices are all dark blue now and won't cure anything. Is there a way to get it back to white? I've tried restarting the computer and using different models.
Vaughan
blue slices bug?
kakapoopie
lond
- Location: Sweden [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: blue slices bug?
Check the slice colour settings under File - Preferences
/// Marcus
/// Marcus
kakapoopie
Ahh thanks Marcus! On that note what's the reasons someone would want to change the color from white?
adambx
If you take RED for example, it filters out most (all?) UV, so you can use it to calibrate your sharpness/position even while you have resin in the vat.
I use blue to make the light more dim to my poor eyes. Works best if used with red resin. ninja mode so to speak...
kakapoopie
ahhh perfect! I've been doing it the stupid way on a piece of paper at the same height as the vat then swapping it out
kakapoopie
nice..been looking for something like that
