so i'm getting a great finish and amount of detail but i'm getting a curve in the x axis. any pointers?
pics to follow when i make them small enough to load
prints curving *solved thanks guys*
JSmith172
- Joined: Mon Feb 02, 2015 2:19 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Scatterplot
Re: prints curving
Post the pics to www.imgur.com, I don't think they have a size limit (within reason).
JSmith172
Re: prints curving
sorry for the bad pics, only have the camera on my iphone
it looks worse in real life
but as u can see with the pegs
the whole think is tilted like this
______
______
- Attachments
- FullSizeRender1.jpg (19.32 KiB) Viewed 35882 times
- FullSizeRender.jpg (18.55 KiB) Viewed 35882 times
Scatterplot
Re: prints curving
It looks like your petri isn't clamped down hard enough, or maybe something wasn't tightened enough during assembly, or perhaps something got tightened at an angle?
JSmith172
Re: prints curving
The Dish one makes sense, since the angle changed directions. i'll try again
JSmith172
Re: prints curving
still getting the curve, in the same spot each time, any ideas?
JSmith172
Re: prints curving
it seems to be right at the height when the prints start to stick out of the resin, is it possible im putting too much resin in? maybe causing a surface tension?
or could it be mechanical? could my balls be out of line on my rails?
- Attachments
- FullSizeRender4.jpg (22.63 KiB) Viewed 35809 times
Phife
Re: prints curving
If you have a dial caliper you should check to see if your Z axis is running straight. From my experience, resin level really shouldnt affect the print unless you run out. Youre curing at the bottom of the resin the cured resin should not curve after its been cured.
JSmith172
Re: prints curving
Solved*
slight off angle caused by a cross threaded screw on bottom
thanks guys
thanks guys
