also going to be trying the b9 casting resin, will be using a mixture of 1:1 red to cherry
will post results
First prints! Starting to print.
JSmith172
- Joined: Mon Feb 02, 2015 2:19 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: First prints! Starting to print.
tried using your prints with the 1:1 mixtures and a exposure time of 8 secs i got the following, got alot of bleeding and the prints where really sticky
- Attachments
- FullSizeRender3.jpg (21.06 KiB) Viewed 16493 times
- FullSizeRender2.jpg (26.36 KiB) Viewed 16493 times
- FullSizeRender1.jpg (28.93 KiB) Viewed 16493 times
goopyplastic
Interesting results, you might try putting a print in water / ipa then setting out in the sun. The liquid may help fully cure the print and remove the stickyness whereas air may be preventing the surface from curing.
JSmith172
I increased my exposure time from 9 to 20 and it comes out ALOT better
only problem is it has a 50% chance of not having enough force to unstick from the vat, its a work in progress lol
