So I've landed a job where I will be researching DLP/SLA printers more or less full time (with a focus on bioengineering though), but aside from my own interests, I wanted to see what are some other topics others would like to explore given time and resources.
What do we want to know more about or start exploring?
Research Topics
AndersonTa
Research Topics
Re: Research Topics
I would have to say:
-Display devices - DLP, LCDs (I know a few work), pico-projectors
-Vat coatings
-Mixed material printing
-Combination UV resin/ inkjet printing - (Stratasys machines)
-Vat coatings
tetelestia
- Joined: Wed Dec 18, 2013 10:18 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Research Topics
One thing I'm curious about is that the Peachy Printer is a bottom up printer which floats the resin on water and just lets the surface tension pull the resin over the top of the printed part without tilting or shaking the resin.
Is this a viable option? Is there a resin with a low enough viscosity and surface tension that it'll reliably flow over the top of the part without being moved.
Re: Research Topics
Hi Anderson,
ask we discussed in the channel,
i'd propose:
- print method - detach from vat(bottom up approach) when going to larger print area's, eg solidator approach?
- automatic support generation, a must
- dlp eco-system, pre-processing, slicing, printing, cleaning, curing, post-processing
- micro-channels - or uncured resin detection in model(stl)
i'd propose:
pizzaslice
- Joined: Tue Jan 21, 2014 9:56 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Research Topics
How does the solidator achieve lift off!? Does it use a non sticking layer, resilient layer, tilt mechanism or xy movement and PDMS film really curious!!?
