Printy! A DIY Open Source 3D Printer!
Let' see your handiwork!
goldi80
Re: Printy! A DIY Open Source 3D Printer!
Postby goldi80 » Tue Dec 13, 2016 6:40 am
this is good !!!!!!!!!!!!
Have galvo but i don't want to use without f theta lens.
Only on the middle you can print and slic3r don't have spot compensation.
Do anyone knows good f theta lesn for sale cheap and do the job.
see photo
maxjewels
Re: Printy! TE Open Source da di fai 3D della stampante di una!
Postby maxjewels » Tue Dec 13, 2016 6:56 pm
In a printer of this kind would serve a LAN connection, a slot for SD cards and a beautiful display.
For the rest is fantastic, I'd like to see in detail the board between the galvo and Arduino
goldi80
Postby goldi80 » Wed Dec 14, 2016 4:20 am
Repetier have lan connection and web Software it works put gcode on it and push start i try it works .
boelle
Postby boelle » Tue Dec 27, 2016 11:20 am
@Gr3ymatter
Any updates?
educa
Postby educa » Sun Feb 12, 2017 4:32 pm
Goldi, if you do the math, then if you throw your laser over a distance of around 250mm, then you can get a 60-80mm square build area with little or no deviation. After that if goes bad quickly but 60x60mm is for example not a bad part to work with
goldi80
Postby goldi80 » Mon Feb 13, 2017 2:27 pm
I calculate the form laser beam is 0.145 dot, wen is on 145mm or from middle 72mm the beam is like egg 0.185 dot.
Regards
educa
Postby educa » Mon Feb 13, 2017 2:35 pm
145mm is also 2.5 times 60mm :)
cozmicray
Postby cozmicray » Tue Feb 28, 2017 5:19 pm
What happened to printy?
any updates?
