nanoDLP - Raspberry Pi DLP Host Software
shahin
Postby shahin » Sat Nov 07, 2015 6:23 pm
adambx
Postby adambx » Sat Nov 07, 2015 6:28 pm
here it is:
test.zip
(249.94 KiB) Downloaded 4985 times
shahin
Postby shahin » Sat Nov 07, 2015 7:06 pm
adambx
Postby adambx » Sat Nov 07, 2015 7:20 pm
works!
shahin
Postby shahin » Thu Nov 19, 2015 2:36 am
shahin
Postby shahin » Mon Dec 07, 2015 12:00 pm
Anyone who are interested can checkout online interface demo of nanodlp
hdfkr
Postby hdfkr » Tue Dec 08, 2015 10:14 pm
Does the latest release allow you to connect to a 3D printer board through USB or is that not yet implemented? I've been trying to connect an arduino nano which is running grbl but I've been having a lot of trouble.
Just moving the z-axis around, when I check the logs it says:
Level Layer Time Module Action Details
UNKNOWN /tmp/go/go/src/runtime/asm_arm.s:1036 (0x7f8ac)
UNKNOWN /tmp/go/go/src/net/http/server.go:1361 (0x195a50)
UNKNOWN /tmp/go/go/src/net/http/server.go:1862 (0x197e3c)
UNKNOWN /home/pi/go/src/github.com/plimble/ace/ace.go:89 (0x9b7b4)
UNKNOWN /home/pi/go/src/github.com/julienschmidt/httprouter/router.go:299 (0x1fc604)
UNKNOWN /home/pi/go/src/github.com/plimble/ace/router.go:132 (0xa0298)
UNKNOWN /home/pi/go/src/github.com/plimble/ace/context.go:130 (0x9c408)
UNKNOWN /home/pi/printer/app/web.go:120 (0x1bb74)
UNKNOWN /home/pi/printer/app/gcode.go:18 (0x10b2c)
UNKNOWN /home/pi/printer/app/gcode.go:58 (0x110fc)
UNKNOWN /home/pi/printer/app/gcode.go:90 (0x11868)
UNKNOWN /tmp/go/go/src/runtime/panic.go:12 (0x4dd5c)
UNKNOWN /tmp/go/go/src/runtime/panic.go:423 (0x4f87c)
UNKNOWN /tmp/go/go/src/runtime/asm_arm.s:424 (0x7d490)
UNKNOWN /home/pi/go/src/github.com/julienschmidt/httprouter/router.go:273 (0x1fc3bc)
and when I hit calibrate zero position it spits out:
Info - 2015/12/09 02:11:58.324372 GPIO Moving to Top
which seems to indicate to me that it's using the GPIO rather than the USB/SERIAL connection.
This is the first time I've done anything on the raspi so it's probably some mistake on my part, but any help would be appreciated!
shahin
Postby shahin » Wed Dec 09, 2015 1:47 am
jkao
Postby jkao » Sun Jan 10, 2016 3:14 am
Hi Shahin,
I finally got around to installing nanoDLP build 947 and getting it hooked up with my printer, which is a Kudo3D Titan 1 printer that is a bottom-up Marlin based firmware with no shutter, tilt motor, or other moving parts besides a Z axis.
Projector control and display is working fine, no issues there.
However, I'm having some problems understanding how the Z-axis controls work.
When I connect to the printer and click on the 1mm down button, the system seems to send a G1 Z1, and if I click the 1mm up button, it also sends G1 Z1. This doesn't seem to match any behavior I would expect in either G90 (absolute) or G91 (relative) mode. If I'm in G90, a G1 Z1 will move the Z-axis to 1mm above zero, meaning the up and down buttons do the same thing and I can only bring my Z axis to exactly 0.1mm, 0.5mm, 1mm, 10mm, or 50mm above the build plate. If I'm in G91, since all the numbers are positive, the stage goes up whether I click on the up or down buttons and there is no way to lower the stage.
Additionally, the Platform Information numbers never change, and nothing happens when I click on either the Calibrate Zero Position or Measure Z-Axis Length buttons.
Is there something I'm misunderstanding about the way that these buttons are supposed to work, or something I'm missing in the 3D printer board setup?
shahin
Postby shahin » Sun Jan 10, 2016 5:23 am
