acer h6510bd serial commands - SOLVED
Re: acer h6510bd serial commands - SOLVED
Postby PacManFan » Mon Feb 16, 2015 2:37 pm
Use an ascii to hex converter. Also, you'll have to manually add a CRLF to the end .
vonhellsing
Postby vonhellsing » Mon Feb 16, 2015 5:43 pm
not wanting to abuse the patience, I have no idea how to do this kkkk
i just put CRLF or have some code
can u helpe me ?
cheers!
angelini
Scatterplot
Postby Scatterplot » Mon Feb 16, 2015 5:46 pm
CRLF means Carriage Return, Line Feed. See the following table:
http://www.asciitable.com/
You can see that Carriage Return is hex 0xD and Line Feed is 0xA. I'm not sure what format exactly you need your hex codes in, but I assume it's two ASCII letters per Hex character, so at the end of your converted string just add 0D0A (those are zeros, not O's).
vonhellsing
Postby vonhellsing » Mon Feb 16, 2015 5:58 pm
I find this factory manual, with this codes IR codes, ASCII, and some examples.
I don't have idea i need put on and off in creation workshop :)
cheers!
angelini
rs232-codes_benqMX613st.pdf
(1.56 MiB) Downloaded 1711 times
Postby PacManFan » Mon Feb 16, 2015 6:20 pm
according to the pdf, you should just be able to send '02'
neurofun
Postby neurofun » Tue Feb 17, 2015 5:45 am
first make sure you select "projector control" in "configure machine".
then click "edit commands" under projector control in the control window.
these are the on off commands for benq projectors:
<CR>*pow=on#<CR>
0D2a706f773d6f6e230D
<CR>*pow=off#<CR>
0D2a706f773d6f6666230D
vonhellsing
Postby vonhellsing » Tue Feb 17, 2015 5:57 am
Wow thx man!!
vonhellsing
Postby vonhellsing » Tue Feb 17, 2015 8:42 pm
neurofun
Postby neurofun » Wed Feb 18, 2015 6:54 am
i use those codes for a benq w1070+ and they work fine.
check your baud rate, for the w1070+ it is 115200baud.
vonhellsing
Postby vonhellsing » Fri Feb 20, 2015 8:22 am
