z axis calibration
faffer
- Joined: Wed Oct 08, 2014 7:47 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
z axis calibration
Hi Steve, My first print turned out just great using your software. I've run into a bit of a problem on the z axis calibration. I've attached some pictures. There seems to be a drift as the z axis distance increases, is there a way to do fine adjustments? or is this a firmware problem? I'm using the Uncia
- Attachments
- Archive.zip
- (900.55 KiB) Downloaded 1387 times
Re: z axis calibration
Can you determine how much it's off by?
Start at a position, and move the z axis 100mm using the software. Measure it and let me know how much it's off by.
Thanks,
Thanks,
faffer
off by 3mm for 100 mm travel
faffer
I did an accurate measurement today 102.8 mm
faffer
Brandon Pomeroy picked up my thread on this issue and did a mod on CW .I get 99.60
attaching his file
attaching his file
dangre, the problem was that CWS approximates the Uncia's steps per mm to be 90, when the actual value is closer to 87. I posted a recompiled version of CWS that had the correct value on the Uncia Google Group.
