Hello everyone
Does anyone happen to know how do I for a limit on the Z axis of a DLP printer that works with the CW , and Marlim , ramps . ?
I thank you for the attention
How to implement limit on the Arduino Mega 2560 and Cw
sodium
Re: How to implement limit on the Arduino Mega 2560 and Cw
this is my working marlin firmware, with upper and lower limits. the upper is for security reasons, but not really needed. check all endstop settings and comments . its easy to understand. Also check #define X_MAX_POS 205 ( change value to your z axis travel ).
dalaura10
- Joined: Mon Nov 10, 2014 1:26 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi, tahnks for your help. I had a problem working with your code.
Look at:
Arduino: 1.6.4 (Windows 7), Placa:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
SdFatUtil.cpp.o: In function `SdFatUtil::FreeRam()':
C:\Users\Windows\AppData\Local\Temp\build8906941252038550266.tmp/SdFatUtil.cpp:33: undefined reference to `SdFatUtil::__brkval'
C:\Users\Windows\AppData\Local\Temp\build8906941252038550266.tmp/SdFatUtil.cpp:36: undefined reference to `SdFatUtil::__bss_end'
collect2.exe: error: ld returned 1 exit status
Erro compilando.
Este relatório deveria ter mais informações
"Mostrar saída verbosa durante a compilação"
habilitado em Arquivo > Preferências.
The sentences are in Portuguese but it does not matter.
Can you help me with this?
thanks
Look at:
Erro compilando.
thanks
sodium
just tried in arduino ide 1.0.6 and compile fine, but not in 1.6.5. two choices:
- compile and upload with the old arduino ide, or
- try to update the libraries yourself.
im not a programmer guru, so try the first option.
dalaura10
sodio
Thank you for your prompt reply
I uploaded with Arduino and now 1.0.5 installed .
My question is :
which pin to use for the end of course , want to take the construction platform for home? If use the pin 18 and returns to the platform a few millimeters , this can not happen because then the construction of the platform is not in the exact house.
My question is :
sodium
you want to use two limit switches? or only the lower one ? i dont understand your question very well ...
really, only one limit switch is needed to operate the printer, the one used to home the machine( Z0 ). i use another one at the other end of the axis for security purposes, but not really needed.
if use a ramps 1.4 shield, you can have two end stop or limit switches per axis.
dalaura10
I'm sorry about my English. Some times I can not write in English as i think in Portuguese.
When i use pin 18 (minimum Z) my plataform goes down, find the dispositive wich closes the pin 18 and GND, and then goes up a few milimeters. I want it to stay exactly where is the travel end without goes back. My aplication here uses a travel end to start printing. I have a dispositive that "closes" the pin 18 when my platform goes to the start printing position.
I do not want it to gooes back after find zero position, i want it to stay there and then i will start printing from there.
I do no know if i am using the correct pin, or something else. But my aplication here is not as i want.
sodium
I dont know if cw directly or marlin firmware do that.
When i hit home buttom, the plataform goes down until hit the end stop. Then, goes back a few milimeters, but quickly goes down again to the end stop posición. At this point , z is 0 and you can start print.
If i understand you, your plataform goes down, hit the end stop, goes up a few mm and stop.
Try enter M114 at command líne and see where z is .
