Resins For Investment Casting
svs
Re: Resins For Investment Casting
Silver castings from customer ODABAS JEWELLERY izmir /TURKEY
svs
svs
snr CAST resin is changing color when cured !!!....You can understand your prints cured well or not ...
Mattasmack
- Joined: Thu Dec 17, 2015 1:11 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
chill74
- Joined: Tue Jun 16, 2015 3:09 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I relocated the color wheel so it is out of the light path. The difference in print time is significant!
jimmyjackson
- Joined: Thu Jul 28, 2016 7:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Can you please suggest some good castable resin supplier in the US ?
jimmyjackson
