Laser SLA reprap
Re: Laser SLA reprap
Alright, my efforts have paid off! Today, I successfully integrated the USB controls for the LaserShark module. Who has a X-Y Galvo system (at least 20kpps), laser and a LaserShark to help me test?
Wabbe
- Location: Novi, MI [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I can help! I'll have a top down system setup by this weekend for testing. It has 20Kpps galvo x-y and 150mW laser.
Wabbe
Sounds great! Yeah the LaserShark is in the mail and I'm currently tracking it
The printer is set to go too. I converted my DLP top down with the laser/galvo setup. I'll just need to adjust the distance of the laser board to the print surface once going for the correct xy. I could technically meet the 4096x4096 for testing if needed, sense everything is adjustable with my setup. The z axis has a 12 inch travel too with floating resin on a saline solution.
Bill
Bill
- @A2
- Joined: Wed Apr 23, 2014 7:58 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
laser cut simple thing with as standard RepRap setup as possible.
Prusa Research Laser Cutting with Prusa Mendel i2
http://www.youtube.com/watch?v=40id30dC ... niRJZRYMvg
Wabbe
System is setup. I have all of the electronics mounted on top with an adjustable z-axis. Figured this would be the best way to increase build size or focus the laser.
I just got my new galvo setup in the mail yesterday, and my laser in the mail today. I just need to wire a few things up for a real test of my code. Probably a few more days before I make a special release for the lasershark setup.
Wabbe
Look forward to testing and helping out!
Which channel are you going to use on the LaserShark for the laser? Channel A,B or C?
Channel C for now, I'll probably make it configurable
jbray6
- Joined: Fri Jun 13, 2014 8:35 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I'm currently working on a galvo-based printer with a 405nm laser, so I would also be happy to test the new creation workshop software if you would like a few more beta testers. Lasershark board (v2.1) should arrive early next week, everything else is ready to go.
