first post after presentation
I'm building a bottom-up SLA printer together with some friends. Direct projection, no mirror at the moment.
In this alpha/test machine I have a vat with a teflon film (not completly transparent... a little opaque but still works great. The UV pass well and the resin cures well) and under the vat a glass to prevent the resin goes down to the projector in case it breaks the teflon film.
As build plate I use a plate of metal sheet with holes.
In my first tests (about 20 i think now) the first layer adhere perfectly on the build plate (so well that I have to use a knife to remove after the printer).
But after some layes (about 10) the new layer don't stink on the previus but on the film (but if I peel of the piece with mi bare finger from the film it come out easily). I know when it adhere on the previus layer because I hear the "snap" sound of the new layer peels of from the film when the z axis lift up for prepare the new exposure.
I was wondering... my telfon film is not good enough? Or I make some mistake about the starting height (in the last test the bottom plate touch the film. Completly tight).
At the moment I use FunToDo resin.
7 second of exposure for first 3 layer. 4.5 second for the other. 0.3mm LH.
I know these are high times, but I try this to make some test. But it didn't work...
I'll post some photo as soon as possibile.
Sorry for my bad english :\
