As I'm trying to lock down some design features, I'm having questions about the top down approach:
1. as the part being printed grows, obviously, the collective shrinkage increases. This will affect the resin level, thus making the top layers slightly thinner than the lower layers.
On the other hand,
2. as the build plate submerges itself deeper and deeper into the vat, the resin level will increase from the displacement.
While both processes kind of compensate each other, the error isn't exact and repeatable. So the question is how do top down machines compensate for it? Is it all in the software? Or is the error so small that it doesn't really matter? Do I need to design a larger volume vat to reduce the errors? (ex a 5% shrinkage error from a 5sq.in. part on a 10x10 inch vat will have very small error)
Would very much appreciate your thoughts
