acer h6510bd serial commands - SOLVED
Re: acer h6510bd serial commands - SOLVED
Use an ascii to hex converter. Also, you'll have to manually add a CRLF to the end .
vonhellsing
- Joined: Sat Feb 14, 2015 10:34 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
not wanting to abuse the patience, I have no idea how to do this kkkk
i just put CRLF or have some code
can u helpe me ?
cheers!
angelini
can u helpe me ?
cheers!
angelini
Scatterplot
CRLF means Carriage Return, Line Feed. See the following table:
http://www.asciitable.com/
You can see that Carriage Return is hex 0xD and Line Feed is 0xA. I'm not sure what format exactly you need your hex codes in, but I assume it's two ASCII letters per Hex character, so at the end of your converted string just add 0D0A (those are zeros, not O's).
vonhellsing
I find this factory manual, with this codes IR codes, ASCII, and some examples.
I don't have idea i need put on and off in creation workshop
cheers!
angelini
cheers!
angelini
- Attachments
- rs232-codes_benqMX613st.pdf
- (1.56 MiB) Downloaded 1459 times
according to the pdf, you should just be able to send '02'
neurofun
- Joined: Tue Oct 07, 2014 9:01 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
first make sure you select "projector control" in "configure machine".
then click "edit commands" under projector control in the control window.
these are the on off commands for benq projectors:
<CR>*pow=on#<CR>
0D2a706f773d6f6e230D
<CR>*pow=off#<CR>
0D2a706f773d6f6666230D
<CR>*pow=on#<CR>
<CR>*pow=off#<CR>
vonhellsing
Wow thx man!!
vonhellsing
neurofun
i use those codes for a benq w1070+ and they work fine.
check your baud rate, for the w1070+ it is 115200baud.
vonhellsing
