Well, I used your config and all I got is this (which looks normal to me):
start
echo: External Reset
Marlinv1.0.2
echo: Last Updated: Feb 6 2015 00:32:31 | Author: (none, default config)
Compiled: Feb 6 2015
echo: Free Memory: 5093 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echo:Steps per unit:
echo: M92 X78.74 Y78.74 Z800.00 E836.00
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z5.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X9000 Y9000 Z600 E10000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo:PID settings:
echo: M301 P22.20 I1.08 D114.00
echo:Filament settings: Disabled
echo:Z-Probe Offset (mm):
echo: M851 Z0.00
Still I cannot move my motor, could anyone tell me if any LEDs should be on or blinking? I really have no idea how to diagnose what is wrong
Simple diagnostics I did an understood:
Tried rotating the motor with LED plugged to one of the coils and it was flashing (so I guest that the motor is working)
Arduino Mega and RAMPS seem to communicate normally with pc,
